支持一下
Button "Play" don't run playing when stoped
Cool skin. How do I view the lyrics window? I am using AIMP 5 beta version.Edit: Nevermind this question, I found out the page changes as you click the cover art in the bottom left corner.But I would like to make one suggestion. It would be nice if the lyrics textbox could have a larger with since the line breaks are a little off.
La letra debe moverse???
The skin is very good. However, I want to change the font. I want you to make a setting that can change the font.
